BROADCAST 1971
Started by road/track, November 26, 2006, 05:16:09 PM
road/track
I'm trying to break down my broadcast (saving +100$ :nana:) but I have some missing parts of information  :smilie_help:, especially in the first part, could any one assist in the correct explaination, I have added the heading and the code, (all of it for the :drool5:) a lot of information is from the 70 Charger registry break down of broadcast (thx a lot :2thumbs:) but I can't find any source for 71 on the web, any one knows where to find it?
SEQUENCE NUMBER; B1?6162
VEHICLE ORDER;      223208059
VIN;                WP29U1A156888
BUILD FOR;             U,   USA
SOLD CAR                4, Customer Order
ENGINE                  E86, 440 4BBL
TRANS                D21, 4-Speed Manual Transmission
AXLE                      D56, Dana 60 Axle 3:54 Ratio
D91, S/G                Sure Grip Differential
T-U-W                T46, G78 * 14 WSW Tires
TRIM CODE                CR X9, Charcoal & Black Leather Buckets
UDF                TX9, Upper Door Frame Color, Black
PAINT STYLE          V01, Single Tone Paint Job
BODY PAINT           EV2, Hemi Orange
ROOF PNT STL TOP V4X, Vinyl Canopy Roof, Black
STEERING COLUMN  515 X9 7005,   4-spd B-body Floor Shift, Black, Power Steering Ign. Lte. Time Delay
STEERING WHEEL    67 X9, ???????????
HORN PAD              66 X9, ????????????
RAD                       39, ????????
INLET HOUSE          57, ?????
ALTERNATOR          72, 37 Amp. Single Pulley Alternator
FAN                       16, 7 Blade Fan
FAN SPA                 12, ????????
BAT                69, 70 Amp. Battery
STRIPE   V           7X, Accent Stripes, Black
VAC FIT                54, Power Brake 1 way without Air Cond. Check Valve connector
ENGINE                  443, 440 4BBL, Manual Trans., Heater, 370hp
CARB                3?, (second digit not readable) ???
TRANS                   755, A833 B-Body Four Speed Manual Transmission
PIN                35, Speedo Gear Pinion Man. Trans. Ornage/35 3:54
P/SHAFT                 105, Drive Shaft 440/426, 9 3/4, (Sure Grip)
AXLE                051, 3.54 S/G, Dana 60, 10" Rear Drum - Front Disc, (A33 Pkg)
WHEELS                52 TX8 59, ?????????????????
WHEEL COVER         24, ???????????
FRAME                74, B-Body Wedge K-Member
FT S/BAR                62, Sway Bar 0,88 In Dia.
SHOCK                56 62, Heavy-duty Shock Absorbers ????
TORISION BAR        781 780, Heavy-Duty Front Suspension Torision Bar
REAR SPRING          794 984, Heavy-Duty Rear Suspension
CLUTCH / BRAKE PDL 64 21, 4-Speed Clutch Pedal & 4-Speed Brakes
LABELS               75 63, ????????????????
EXHAUST               93 76, ????
TAIL PIPE               79 78, ??????????
CAR HIGHT               BP3, Standard Car Hight
MAS CYL               45, ???????????
FRONT BRAKE         67 66, ????????
CONSOLE               C16, Console w/Woodgrain Panel
REAR ARM RESTS    C23, Rear Armrests w/ashtray
SEATS               C5   5, Bucket Seats
CARPET                 C9   3, Carpet
SPARE TIRE COVER C9   6, Trunk Dress-Up Partial
BRAKES DISC          B4   1, Front Disc Brakes w/Standard 10" RR Drum
BRAKES POWER      B51, Power Brakes
COMBINATION GROUPS A33, Track Pak w/3.54 ratio
MIRROR O/S LT RT  G36, OS Dual Racing Mirrors
MIRROR INSIDE       G41, Day/Night Inside Rear-View Mirror
HEATER                 H11, Heater
BATTERY               F2   5, Battery 70 Amp Hour (Series 27 w/Red Caps)
OIL PRESSURE GUAGE   F96, Oil Pressure Gauge
GLOVE BOX LOCK    J11, Glove Box Lock
ELECTRIC CLOCK     J21, Electric Clock
HORNS               J31, Dual Horns
PEDAL DRESS UP    J41, Pedal Dress Up
I/P HOOD RELEASE J52, Inside Hood Release
MAP COUR LITE      L05, Map Courtesy Light
GLOVE BOX LITE    L11, Glove Box Light
ASH REC. LITE       L15, Ash Receiver Lamp
CARGO TRUNK LITE L2   5, Trunk Lamp
ROAD LAMP CONC HDLP L37, Concealed Headlamps
DRIP TROUGH        M2   1, Roof drip rail moldings
WHEEL LIP            M2   6, Wheel Lip Moldings
MSC MLDGS           M4   2, Front Stone Shield Moldings
WHEEL SKIRT MLDGS   M44, Hood and Fender Moldings
ING SW TIME DELAY   L65, Ignition Switch Lamp  /with time delay
DUAL EXHAUST     N41, Dual Exhaust
FAN HI CAP TRQ DR N65, 7 Blade Torque Drive Fan
COOLING LESS FAN  N   51, Maximum Engine Cooling
SUSP                S15, Hemi Suspension with Sway Bar
SHOCKS                S25, Firm Ride Shocks 1" Front & Rear
POWER STEERING   S77, Power Steering
STRG WHEEL          S81, Premium Steering Wheel Woodgrained
WHEELS                W21, Rallye Wheels
(I'll be on a course for a couple of days and not sure if I'll be able read any answers before Thursday)
-1971 Charger SE U-code 4spd track pack, one of 29...
-1971 Charger R/T 440 6 pack auto
-1961 Chrysler 300G CV, one of 337
-2014 BMW 435i M-sport
Brock Samson
Nice car!  you got some pics of that?..   :icon_smile_tongue:
Alaskan_TA
HORN PAD              66 X9,
RAD                       39, ??
INLET HOUSE          57, ??
FAN                       16, 7 Blade Fan
FAN SPA                 12, ??
WHEEL COVER         24, ??
LABELS               75 63, ?
EXHAUST               93 76, ?
TAIL PIPE               79 78, ?
MAS CYL               45, ??
The two and three digit numbers in the section above are the last two or three digits of the actual part number for those parts. Galen's pocket books for the part and casting numbers are a great place to look these up.
Some of the others,
X9 is black, color of the parts for your steering column and parts.
TX8 - Paint code for your spare tire.
CAR HEIGHT               BP3, B is B-Body, P is power steering.
MAS CYL    45, ??   45 is power brake bosster assembly.
Barry
