engine balancing
Started by mally69, November 03, 2006, 11:00:25 PM
mally69
ok  i have a 440  that im going to need to be balanced i know i need the following
pistons and rings
rods
crank
dampener
if im going to run a 4 speed what needs to go with the parts listed above???
if its an auto do you need the flex plate?
The flywheel should already be balanced and if it's an auto, you don't need to send in the flexplate.
Runner
Quote from: Ghoste on November 04, 2006, 09:21:33 AM
  i would send the flexplate. i have one the last 2 engines ive had balanced
Runner
also dont forget a set of rod bearings
I stand corrected on the flexplate.  I've never sent one in before, did it make much difference?
If the engine is to be internally balanced then you don't need to send in the Dampner or Flexplate.  ;)
send the damper & flywheel , even if they are balanced it doesn`t hurt to have them checked
mally69
ok guys thanks i just wasnt sure on that.      what do you guys think about  440source's fluid dampeners???  any you guys use them
mally69
does the pressure plate have to be balanced just as the flywheel would?
Quote from: mally69 on November 05, 2006, 08:22:02 AM
Not a fan of fluid dampners...their balance cannot be checked due to the viscious fluid inside. I would use a good quality sfi elastomer type dampner. The fluid dampners are often very heavy and the fluid can go solid...throwing engine balance way out of whack and tearing up the bottom end. Some people like them but i sure wouldn't run one. Summit Racing carries the SFI elastomer dampners at a reasonable cost.   ;)
If you're having this engine internally balanced, the dampner and flywheel should not be on the rotating assembly during the balancing process inmo. Balancers and flywheels/flexplates for internally balanced engines are neutral balance. You could have them checked out for neutral balance if you wish, prior to assembly.
mally69
ok  that should straigten things up, that whole balancing was kind of a grey area to me  but thanks
Challenger340
Quote from: firefighter3931 on November 05, 2006, 07:18:33 PM
BUMP !
GREAT ADVICE  !
Only wimps wear Bowties !
tecmopar
Do as Ron said, have the flywheel/flex and dampener checked, I've seen quite a few that were off by a tad, good luck.
