removal of trim on 2nd gen
Started by rusty lee, October 24, 2006, 02:21:22 AM
rusty lee
Is there a tool to remove this trim? And if not is there an easy way to remove without breaking? Thanks
Winged 1
 ;D
Screw drivers, from the inside after you remove the upper pads..
Good luck,
Eric
rusty lee
what do you mean by upper pads? and does that rivet head need drilled?
THE CHARGER PUNK
no the interior upper door pads, u use a screw driver and pop out the head of the trim which connect it 2 the car , be careful :icon_smile_big:-MATT
rusty lee
so from the inside of the car? there is no interior at this time. BUT do they make a tool????? I don't want to mess up the trim. thanks
rusty lee
Anyone??? Some one has to know a trick or two on how to remove this. I already broke one trim piece don't want any more getting trashed.
bill440rt
Do NOT drill that little rivet!!!  :scared:
The 1/4 panel belt molding is pretty simple to remove once you know how. I've always had to remove the 1/4 glass to get the molding off, but some other members here didn't have to. The rear upper interior pad first must be removed. Then, remove the window fuzzy on the 1/4 panel. You'll see small Phillips sheetmetal screws holding this molding on. Take those off. You then need to carefully lift & slightly twist it to detach it from the drip molding. It should then lift out.
Good luck!!
Shakey
Here are a couple of pics of the driver's side of a '69.
Hope they help.
rusty lee
ok removed all trim successfully. thanks for pics and advice.
