VHT Epoxy Paint. Opinions?
Started by Old School, October 20, 2006, 07:32:36 AM
Old School
Does any one have any opinions on the VHT Epoxy Chassis paint? Or maybe a better alternative?
bill440rt
I've always liked Eastwood's Chassis Black. It's available in several gloss levels of black, covers nice, & holds up well.
More specifically, what are you painting???
Old School
I'm painting the chassis , rearend, basically the undercarriage.
bill440rt
The unibody "chassis", or just the underside of the car, should be primer with body color overspray for correctness. Other people like to spray the entire underside body color for over-restoration.
If you're just building a driver, the semi-gloss Chassis Black is a close match to go over factory undercoating. A nice, clean black look.
The rear end could be sprayed with Gloss Chassis Black. I prefer using this stuff over regular spray paint anyway, it is much more durable.
It comes in big spray cans. It covers very well & one can will go far. You'd probably use about 3-4 cans under a car.
Good Luck!
BigBlockSam
QuoteEastwood's Chassis Black
good stuff  :yesnod:
