I cant find the console plug
Started by tommymac, October 10, 2006, 07:29:18 PM
tommymac
I have a 68 charger that was a column shifter,traded steering column and installed console,now i cant find the plug for the console wiring.It's not in the usual places i've read about. Can anyone help...Rewire,splice.????
Back N Black
I just did the same change over, you will need the complete 3 piece wiring harness from a donor car.
Harness #1  runs from the fuse box and end at the driver's kick panel.
Harness #2  from the kick panel down the  driver's side just below the sill plate and under the driver's seat.
Harness #3  the one with the light sockets that attaches under the console.
Hope this helps.......
tommymac
thanks fr the info ,i found the proper wires and spliced them in.consol lights and all work  fine. I found a small two pronged female plug to the backup lights on the heater box .they work now.
