Gauge Removal
Started by JMF, October 10, 2006, 02:59:34 PM
JMF
My temperature gauge is broken on my 1968 Charger, now before I do anything does the gauge come out seperately or does the whole cluster have to come out? Thanks
Carrnutt
you have to take out the entire cluster in order to replace or repair the guages :(
1969 Rest-O-Fied Charger 383HP, Disc brake conversion, electronic ignition.
1993 D350 Curmmins
2006 Magnum R/T AWD
2003 Ram 3500 Cummins
JMF
Damn, i'm going to get someone to check again first that it's the actual gauge but I think it is as nothing is happening
Carrnutt
Sorry, but u might wanna replace the sending unit first, easy and cheap. and wouldnt hurt, maybe test the wires at the terminals on back of guage. One is 5 volts constant with ignition on and the other shoud have ground resistance decrease as temp goes up, thereby makin the guage move more and more. it could be in the wiring saving the trouble of removing the cluster. hopefully u find it and its an easy fix for u :)
1993 D350 Curmmins
2006 Magnum R/T AWD
JMF
Cheers, if it is the gauge are they easy to repair and are there places that offer a service to do this?
Plumcrazy
Quote from: JMF on October 10, 2006, 03:53:12 PM
Just because the gauge won't move doesn't mean the gauge is bad.
JMF
I know but the gauge is slightly twisted in the dial and it looks kind of odd
