stock distributor wiring problem
Started by chargerman68, October 10, 2006, 02:21:11 PM
chargerman68
have stock 440 distributor.has a pigtail with tan/black wire.does the tan wire go to pos lead of coil,blk to neg lead coil.got it with both tan/blkj wire fused together and just one wire to pos lead of coil.thanks
Carrnutt
sounds like an electronic distributor? wires would go to ignition module not coil. Points only have one wire and it goes to (-) neg coil post. At least best i can remember, can't seem to find my electronic ignition upgrade files.  :rotz:
1969 Rest-O-Fied Charger 383HP, Disc brake conversion, electronic ignition.
1993 D350 Curmmins
2006 Magnum R/T AWD
2003 Ram 3500 Cummins
chargerman68
has one wire comes with a pigtail.two wires from the distributor to a pigtail.the other side of the pigtail has to connectors on it for the coil.
chargerman68
do u have a pic of each of these distributors.electric/points
thanks
Carrnutt
well, open the cap if it looks like this pic of a dual point, maybe thats what u have but should still have only one lead wire. But do you mean it has 3 wires total? I dunno what that is  ???, maybe a conversion or ???
1993 D350 Curmmins
2006 Magnum R/T AWD
the ECU has 5 wires , Blue to 12 V power , blk to - Coil , & the 2 wires to the dist , the 5 th wire is green & not used
Used just if you have double ballast resistor to the 5 pins module
5 pin modules were only made for 3 years , & oddly will work with the green wire disconnected
