cam selection
Started by 01MOPAR, October 05, 2006, 10:19:48 AM
01MOPAR
Which would you run in a mild built 440 with 2400 converter?
lunati voodoo                                               or                        mopar purple shaft  280 474  110  lsa
Advertised Duration IN/EX: 262/268                                          2000-5900
Duration @ .050 IN/EX: 220/226
Gross Valve Lift IN/EX: .475"/.494"
LSA / ICL: 112/108
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 1400-5800
andy74
The voodoo cam would be my choice,but i wouldnt switch if i already had the purple shaft-just my 2 cents
01MOPAR
which would make the most power?
andy74
Quote from: 01MOPAR on October 05, 2006, 01:02:42 PM
the voodoo cam will make more power ,just due to the more modern lobe design,and will also have a more friendly street power band,should also have more vaccum for power brakes/accesories and will idle cleaner-remember they have had a lot of technology increases in cams over the years and the mopar grinds are still old style tech,not bad-just better stuff available now
Quote from: andy74 on October 05, 2006, 03:05:40 PM
:iagree: The Lunati will have a faster lobe action letting more air in sooner and holding it in longer. That translates into increased power and better street manners/drivability. If you're starting from scratch...the Voodoo is the way to go.
I agree the VooDoo is better
deputycrawford
Me three for the Voodoo cam.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
Rolling_Thunder
