440 bore size
Started by 01MOPAR, October 03, 2006, 09:21:19 AM
01MOPAR
I have a 440 that will need a bore job and i was wondering if their is any advantage of power in  the bore size such as 30 over or 40 over?
bore as little as possible , the stiffer the cylinder walls the more power you will make , if the block will clean up at .010 & you can get pistons do it
