stall speed?
Started by 01MOPAR, September 14, 2006, 11:30:55 AM
01MOPAR
Whats the stock converter stall speed on 69  727?
RD
matters on the engine that it was put behind.
Size counts, the 225, 318, 340, 383-4 and Hemi use the 10 3/4" converter, all others use the 11 3/4":
69CoronetRT
Application also matters. Notice the 383-4bbl converter for A/B body is different than the C body. The A/B body 383-4 is the same as the 340 converter.
01MOPAR
what would be a perfect street  converter for a 440 with a mild 270-280 range cam on a 110lsa?
deputycrawford
I would say 2500- 2600 ish range on the stall. You could use an aftermarket 11 inch converter for that. Cost would be low too.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
