Weiand intakes
Started by darkside, August 15, 2006, 10:53:14 AM
darkside
What do you guys think about the wieand action plus for the 383?I have a performer rpm and a action plus.I think the wiend intake will work with all the factory throttle bracks and kick down.Just tring to decide which intake to run
471_Magnum
Good dual plane. Just a bit taller than a factory intake.
darkside
wiil it work with stock linkage and throttle brackets?
it should be within the adjustment range
darkside
Anyone have any pics of the weiand intake on their big block?
deputycrawford
I don't have pics but I do run the RPM intake on my 383 with all the original brackets and kickdown setup. I also still run the stock throttle bracket and cable. It does adjust.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
4402tuff4u
I went with Neil's (ChrycoPsyco) suggestion and so far I'm happy with the choice. Will let you know hopefully by next week how she runs. Scheduled on having the cam/engine break-in next week. Since I used the INDY EZ heads, my engine builder had to shave off the heat cross chamber off the bottom of the manifold. If you are using stock heads and the tin valley pan, you will not need to do that. I had to use the INDY valley plate cause the heads stick up about 1/2" - 3/4" higher that the stock heads. The intake had all the threaded holes for all the throttle linkage attachments and accessories - no modification needed there. The only thing I had to modify was the A/C brackets so my compressor could sit properly and in line. I also had to modify the air filter pan to compensate for the additional height the INDY EZ heads raised my intake.
"Mother should I trust the government?........... Pink Floyd "Mother"
4402tuff4u
this one shows all the attachments and it looks very close to "stock".
darkside
myk
Quote from: 4402tuff4u on August 17, 2006, 06:17:24 AM
So you went with the Weiand action plus, right?  I can just make out the Weiand name in the pictures.  I'm glad to see that you can use your stock brackets, linkages, etc.  Did you ever get this thing running?
4402tuff4u
Quote from: myk on September 11, 2006, 05:05:15 AM
Yes it's running beautiful besides an annoying little oil leak that I'm trying to trace. I'll take few pictures this week. Yes that is the Weiand manifold. Everything stock bolted up with no problems. Plenty of power!!!  :2thumbs:
myk
I'm glad to hear that your motor turned out so well.  I'm also glad to hear that you were able to use all of your stock linkages, brackets and whatnot, as I'll be looking into getting a Weiand intake also...
dodge freak
If that vacuum gauge is not steady when you check the vacuum on your motor MYK I would pop the heads off and take them to a good shop for a valve job. Its not that hard-just make sure you drain the coolant out, theres a plug on each side of the block that screws out. Then you unbolt the exhaust manifolds or headers and take all the head bolts out. I like to just crank the motor over till the heads pop loose-keep a few bolts in the head loose so the heads don't fall off.
myk
That's not a bad idea.  It'd be a chance to have some work done to the heads, also.
Someone else here suggested that hooking up the vacuum gauge to the intake manifold to brake booster hose may have caused an erratic reading.  It was then suggested that I try hooking up the gauge to the PCV port on the 'carb; I'll let you guys know how it turns out...
4402tuff4u
Myk, if you go with the Weiand, makesure you will not have a hood clearance problem. I believe they sit a bit (1/2") higher than the Eddys or Holleys.
Brock Samson
i got the Stealth, works fine i think, seems to get out of it's own way..
myk
Quote from: 4402tuff4u on September 13, 2006, 08:23:34 AM
Eeek.  Thanks for the warning.  Hood clearance issues may be the deciding factor between the Weiand Action Plus or the Holley Street Dominatrix, or whatever it's called.  Apparently, the Holley is a low profile intake which should guarantee that I will be able to use my stock linkages, cables, etc..
4402tuff4u
Quote from: myk on September 13, 2006, 03:41:03 PM
I had to modify my air cleaner, but everything worked out good. Just check the spec's on all manifolds, they will give you two dimensions and take the average of both measurements.
http://www.dodgecharger.com/forum/index.php/topic,17791.0.html
Challenger340
Great looking engine !  Gotta luv those INDY heads, you've done an awesome job, it looks fantastic !
Only wimps wear Bowties !
