2nd generation Charger door window seal?
Started by COKE, August 12, 2006, 06:16:03 PM
COKE
Hello,
Were can i find the  vertical seal that is mounted on the metal channel on the rear of the door window?
I mean the part that seals the door window whit the rear quarter window.
I have found this but not sure if it is the part:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260011136048
It is for a 69 Charger.
Thanks for the help.
69´Charger R/T,440 ,4-speed,Dana 60 3.55.
8WHEELER
Everywhere, YO, Paddock and Laysons every company I know sells them repop, they have been out for years.
Dan
:iagree:
The one in the auction is correct as well
Dennis K
Dante's parts just recently started selling the quarter window seals with the correct flocking on them. The ones from 1A Automotive on ebay are the bare rubber seals. I know because I bought a pair from them. I am going to buy a pair of the flocked ones soon. If you want my brand-new bare rubber seals that I got off ebay for free plus the cost of a padded envelope and postage, PM me. check out www.dantesparts.com
charger Downunder
What i know the repo,s are crap it will be interesting to know if the seal with the flocking on it will have the corect molded top.
[/quote]
autodynamics
i have an extra set let me know if u need...pete
Dennis K
I did a little research and I found that the flocked ones are made by Metro moulded parts. It doesn't look like they have the moulded end on them, but they have to be much better than the previously available unflocked ones. My brother in law just finished his 68 Charger, and on hot days the rubber grips the quarter window so much that he has to stop, park the car, open the door a little, roll the window down/up and then go again, or leave the quarter window down a little ways all the time.  Here's a pic on the Metro website.  http://www.metrommp.com/productimages/640/VS7EFL.jpg
COKE
Hi thanks for the help, ;)
I,m asking because i ordered a pair from Yearone once,an i received these:
And i would not like more wrong parts.
No idea for what car are the parts on the picture .If someone wants them i can send them ,only will have to pay the shipping.
What do you mean with "Flocked"?
Do you mean that it comes with the felt part on it?
Thanks.
Dennis K
The parts in your pic are the parts that go inside the door, in the channel that the trim part on the back of your door window goes into when your roll your window down, so now that you know, you may want to check the ones in your doors before you get rid of them. "Flocked" is what they call the fuzzy velvet-like texture that is present on the parts you posted the pic of, and the weatherstrips that you originally asked about are also supposed to have the fuzzy texture.
COKE
You are right Dennis..
Thanks for the info. ;)
COKE
Hello again,
I have get the seal fron Dante´s.
It sems to be very long.Should i cut a portion or does it  go  into the door?
It should to go glued to the channel?
Thanks in advance. ;)
Dennis K
I have an original one here, and it measures 20 1/4" long, so if yours is longer you'll need to cut it to fit the channel, and yes, they were glued into the channel with weatherstrip adhesive.
COKE
Yes these also measure 20 1/4.
Then there is a part wich goes into the door.I was not sure because my old seals are missing.
Thanks.
