Radiator temp and heater fluctuation
Started by Dino, January 06, 2025, 06:06:55 PM
I took the Charger to work this morning. It was just shy of 20 degrees. The heater works well, but only when cruisin. At higher speeds/rpm it doesn't seem to do so well. As soon as you start coasting, you can feel the heat rush through the vents. I also had a few instances where the water temp would go from 185 up to 205-220, and right back down. I'm not sure what's going on. I noticed the heater do this a while back when it was 45-50 out. I don't think I've ever seen the water temp do this. I flushed the system a while back. Do I have air in there or something?
70 sublime
Sounds like thermostat doing what ever it wants
I didn't think of that. I'll replace it. Thanks!  :2thumbs:
Wingnut426
I had that problem once, the lower hose was sucking itself closed. I forgot to swap the wire/spring from the old hose before replacing it.  Put the wire/spring in the new hose and it was fine after that.  :Twocents: WINGNUT
HEMI Daytona Convertible
69hemibeep
I got my spring from a Mustang shop online.
