2 post lift for low garage ceiling
Started by timmycharger, January 03, 2025, 10:01:29 AM
timmycharger
at 50+ years old, it is getting less fun to roll around on the ground when wrenching.  I am planning on swapping my engine in the future and want to do it the way I did it 8 years ago and like the factory did it by pulling the body off the K frame.  Last time I bought a US Tool rig for an engine crane but been kicking around the idea of a 2 post lift.
my ceiling is about 9ft 3 inches and there are many lifts out there that will fit but looking to see if anyone has one in their garage and any preferred brand.  Saw many that do not have the top stabilizer beam and are rated for 9000 lbs.
Ill have to use a chair to roll around in but it beats being on my back.
Anyone have one in their low ceiling garage?
Kern Dog
You do have to think of the math of it all.
If the car sits over 4 feet tall at the roof and if you are around 6 feet tall, you need a bare minimum of 10 feet of clearance to be able to walk under the car on a lift.
I knew a guy that wanted a lift in his single story garage. I told him that I could modify his garage roof by cutting the truss webbing and framing in rafters and joists. We never got around to doing it, though it is still a good solution.
Good luck.
timmycharger
Yea, I know if I put in one for low ceilings, I won't be able to stand under it, that is ok with me, Ill just use a rolling chair/stool.
When we had our garage built (3 car, 20x 40) we had the choice to have high ceilings or have a second floor. We went with the second floor which was a good call as it is our storage space since we have a finished attic and basement.  They used pre fabbed trusses which I agree could be modified but that would eat into a good part of the second floor and not what I want to do as some day when I sell this house, the next owners may not want a lift in their garage.
Here is a shot of my garage, plan is to put it where I park the Charger, third bay on the right.
70 sublime
I have thought about putting a lift in my shop also
Think what is holding me back is how much I would use it vs how much it will be in the way all the other times I do not need it
The not need and in the way time is winning at the moment
There are several 2 post lifts that are designed for 8-10' ceilings. Some have the top cross beam. I'm not sure if any are ALI certified if that matters to you. They also make height adjustable reclining mechanics chairs to make working under the car a lot easier. I'd probably bolt some caster under an old Lazy Boy.  :lol:
My concrete floor is going in this spring and I'm getting a 4 post lift to start. I will need it more thsn a 2 post and I like the added security. I do have 14' ceilings in my new place and may add a 2 post when I start lifting bodies off frames.
1970Moparmann
I kept on going back and forth about the Quickjack/Maxjax and or a mid-rise lift like the Bendpak.   I then found the EZCarlift - https://www.ezcarlift.com/ .  I talked to the owner/inventor for a while and like the practicality of it versus the size of the MaxJax and the mid-rise lifts.   I then thought to myself that I didn't want to do any cement work, which led me to get a EZCarlift.   For the amount of time I use it, it fits my needs.   Look it up.   It comes with a wall mount so you can hang it when not in use.
NHCharger
I have a Titan scissor lift in my shop. It has a total rise of 54". Very handy. Only drawback is because of its design it makes working on exhaust systems difficult.
I had to replace the engine in my Daytona clone a couple years ago. I used my cherry picker engine hoist to pick the front of the car up so we could remove the engine and K frame from below.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
Quote from: NHCharger on January 04, 2025, 09:30:02 PMI used my cherry picker engine hoist to pick the front of the car up so we could remove the engine and K frame from below.
That's how I installed mine. It was easier than I thought.
Kern Dog
That method may be easier than using a 2 post lift.
I remove the hood, manifolds/heads and fan/Alt. then unbolt the trans. to pull with a picker.  :scratchchin:
timmycharger
Appreciate the responses, I have been looking at the Maxjax and Bendpak ones, I will check out the EZcarlift one as well, thanks for the suggestion.
The lift is not just for the Charger as I do all of the maintenance on the family vehicles and getting tired of rolling around on the ground.
Quote from: NHCharger on January 04, 2025, 09:30:02 PMI have a Titan scissor lift in my shop. It has a total rise of 54". Very handy. Only drawback is because of its design it makes working on exhaust systems difficult.
Yes, this is how I did it 8 years ago with the U.S. tool rig, worked just fine but now I will need to buy a cherry picker as that one was borrowed.
Quote from: b5blue on January 05, 2025, 09:04:10 AMI remove the hood, manifolds/heads and fan/Alt. then unbolt the trans. to pull with a picker.  :scratchchin:
Been there/done that a dozen times, different ballgame with 2 inch TTI headers and a 4 speed with a Lakewood blow shield.
Wow nice! Quite a bit more.  :2thumbs:
Kern Dog
To those that ponder the installation of a car lift:
* You think that you might not use it much? I understand but for the times that you do, it sure makes jobs easier and faster. You can have a rolling tool cart next to you as you stand up to do the work instead of laying on your back while looking for the wrench that is actually right next to you but hard to see and find.
* You don't want to spend the money? What are you saving for? If you are covering your bills, why not treat yourself? Most kids are ungrateful assholes that have no interest in your cars so spend your money on yourself and leave them with nothing. You earned your way in life, let them earn their own way. Those that complain, fuck them. They need to learn the old fashioned ways to survive and thrive. Too many kids have it easy and that needs to end.
Kern Dog
That is a nice looking place, Tim. The three car garage is a nice touch too.
The majority of the use that my lift gets is suspension and brake, oil changes, tire rotation and axle bearing work. Having the ability to stand while working is so much better than leaning over or sitting. Because of that, maybe a lift that isn't so tall would still be useful.
If I had a place with a ceiling too low for a traditional 2 post lift, I'd look for a way to modify the ceiling. I used to be a Carpenter and roof framing was my specialty. When the wife and I were contemplating a move to Arizona, when I saw a garage with a low ceiling I wasn't immediately deterred.
I have some free time....If you pay for air-fare, I can fly out and offer some ideas.....
Kidding, of course.
timmycharger
Ha! Thanks man. I'm sure you could have plenty of ideas, would love to tear into that ceiling but I don't know how long I will be at this place and the next buyer may not be into cars and would rather have the storage. I would have to move the urinal I installed up there too haha.
I'm still looking into it, next step is to drill a hole in my floor and see how deep it is before I even get more serious.
My daughter's 2015 Charger needs all sorts of front end parts, I would love to not be rolling around for that job. I have so many other future projects that I can use it for so If I have to roll on a chair then so be it. I can still weld an exhaust or run brake lines.
