Final Sanding for color coat question
Started by AKcharger, November 24, 2022, 10:57:31 PM
AKcharger
Howdy!
OK the PPG data sheet says topcoat primer surfacer with 400 grit dry or 500 wet, Problem is there isn't 500 grit only 600. Is 600 too fine? I know the 400 dry is gonna load up FAST so prefer wet.
hemi-hampton
if your going to use basecoat, especially metallic base coat then 600 wet. I prefer 400 for single stage. Like I said before, Seal before painting although some will say sealer optional. :slap: LEON.
P.S. Just my opinion, I'm sure others will vary :scratchchin:
AKcharger
Quote from: hemi-hampton on November 25, 2022, 12:41:08 AM
if your going to use basecoat, especially metallic base coat then 600 wet. Like I said before, Seal before painting although some will say sealer optional. :slap: LEON.
600 wet...Copy that Sir!
AKcharger
hemi-hampton
Here's a Black Metallic Chrysler 300 I just Painted last Week. The 1/4's were so Rusty I had to remake them with fabricated Patches. The 2nd pic is it in Black Sealer. LEON.
Mopar Nut
Looks awesome! Well done. Black is hard to get straight like that.
AKcharger
So Leon, do you do any Sanding or scuffing to sealer or let it dry and shoot color?
hemi-hampton
Per the Data Sheet I let it dry for at least 20 Minutes then shoot the Base & then Clear over it. Unless I'm doing a School bus, Then I shoot white sealer over it & put 2 coats single stage school bus yellow. I must of sprayed a thousand gallons of that stuff past few years  :brickwall: LEON.
hemi-hampton
Off subject but the rusty Dog Leg on that Rusty POS Chrysler 300. A quicky Patch Job. LEON.
AKcharger
Man makes me feel old to see a "new" car rusty. Good work as always!
AKcharger
1st Blocking complete 2nd primer coat on and blocking in-progress!
