Hood hardware question 1969
Started by C500, May 27, 2022, 03:44:57 PM
C500
Hey folks... the new AMD hood doesn't have holes to attach the latch hardware at the front ... can someone please assist with measurements where to drill the holes... in millimetres? Thanks in advance...
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
Mopar Nut
Quote from: C500 on May 27, 2022, 03:44:57 PM
What year Charger?
C500
Quote from: Mopar Nut on May 28, 2022, 12:14:28 AM
What year Charger?
Good question....'69 👍🏻
Daytona R/T SE
You've got bigger problems than just missing holes.
The latch hardware mounting holes have threaded inserts in them from the factory.
You can't just drill a few holes and put self tapping screws in there...
:Twocents:
Mopar Nut
Post some pictures of where the latch would bolt up to on your new AMD hood.
RTSE440
These may help but you need to buy the rivet gun to suit i have a really good Italian made one which is quite expensive but they make a cheap Chinese one which would probably do the job.
https://www.ebay.com.au/itm/363855024062?hash=item54b7730fbe:g:yoUAAOSw3OJikv8G
C500
Thanks, I just need some measurements on where to make the holes now
C500
anybody out there that can take a tape measure to a 68-69 hood?  :popcrn:
Ryan
id be calling amd and asking for a new hood. Those threaded inserts should be there. Every AMD hood I have touched has had them.
69 charger r/t Triple Black
   572 HEMI, Passion 5 speed, 4.10 Dana under construction
2014 viper TA
70 sublime
Just drill it and use hood pins only ??
C500
