73 Dodge Charger 400 big block dyno
Started by Michaelgt450, November 19, 2021, 12:48:47 PM
BSB67
11.68 @ 120.2 mph
Michaelgt450
So I checked the compression on one cylinder it came out to be 145.... tested cylinder number 2 came out around 155 the car was cold didn't know if I needed a warm it up or not
metallicareload99
Quote from: Michaelgt450 on November 23, 2021, 02:32:11 PM
Nice car! I've heard the "right way" to do a compression test is plugs out, throttle open, battery charged, engine to operating temp. I always do all the above, but usually the engine is cold.
145 to 155 seems ok, but I think you really need to test all 8, in the same conditions and go from there
Michaelgt450
Quote from: metallicareload99 on November 24, 2021, 03:35:42 AM
I didn't do the Full Throttle open with that give a different reading I'll check them all
