Frame kinked...
Started by Fitz73Chrgr, September 11, 2021, 03:44:56 PM
Fitz73Chrgr
A few years ago, I went to get my '70 aligned.  The shop did it, but told me they couldn't get it quite right because they ran out of threads on the driver side tie rod.
This winter, I believe I discovered why:
On my driver's side front frame rail, I discovered a seemingly minor kink (if a frame kink can be considered minor).
My question:
Assuming that there are no other problems to be encountered, what cost am I looking at to get the kink straightened on a frame machine?
What type of disassembly would be required?  Front bumper, fenders, rear bumper?
'73 Charger - project                '70 Charger - driver                 '66 Charger - survivor
Resto thread:
http://www.dodgecharger.com/forum/index.php/topic,89803.msg1019541.html#msg1019541
Fitz73Chrgr
Resto thread:
cdr
sounds like the steering wheel needs to be pulled off & centered so the tie rod adjusters are = left & right side
Fitz73Chrgr
Quote from: cdr on September 11, 2021, 03:53:10 PM
The wheels are not in perfect alignment with each other.
Resto thread:
cdr
Quote from: Fitz73Chrgr on September 11, 2021, 04:15:40 PM
I get that, set the total toe & then pull the steering wheel to get it centered
cdr
take some pictures of your left & right tie rod adjusters I bet one side is all the way short & the other side is much longer due to a bad alignment job
cdr
also get some pictures of the kink, when the frame rail were stamped out they can have some kinks,wrinkles in them, it would have to be bent REAL bad for what you are describing
