Odd scraping noise in recently rebuilt 383 (68 Charger)
Started by BrokenHero, June 26, 2021, 09:18:47 AM
BrokenHero
Engine was recently rebuilt and also tuned up, spark plugs regapped, carb adjusted, etc.
It started doing this out of nowhere, a few weeks ago. Rough scraping noise.
Any ideas? Short video link below.
https://youtu.be/gBxt6ktV7TY
1968 Dodge Charger
383 4 barrel
PP1 red, black vinyl top
Los Angeles, CA
Dodgecharger74
74 charger se
82 dodge PU fleetside short box 440
05 magnum 5.7 Hemi
04 rumble bee hemi
Disconnect the fan belt temporarily to see if the noise stops.
Alaskan_TA
Converter bolt heads contacting the webbing at the back of the block is a possibility.
Were the correct factory type thin head bolts used? Were they all tightened correctly? If so, converter fully seated first?
Another possibility that can make that type of sound is a loose harmonic balancer.
Could even be the flexplate rubbing on the gravel shield (if you have it installed)
