LCA shaft torque
Started by jlatessa, May 02, 2021, 11:18:04 AM
jlatessa
This on a 70 Charger,
Is it  140 F.P.s as the FSM seems to require??
Thanks, Joe
birdsandbees
Yep, with the car sitting on it's wheels and ride height set.
That said, if you have aftermarket PST shafts I found that their steels threads won't make it beyond 100 ft-lbs.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
QuoteThat said, if you have aftermarket PST shafts I found that their steels threads won't make it beyond 100 ft-lbs.
The threads strip more easily?  As in, the steel is softer than original?
Greeeaaaat . . . .
birdsandbees
Yeppers. When I torque something I work my way there at 10 or 20 ft-lbs at a time. I got my passenger side up to 100 on the Bee and then the drivers side started to say no at 100. So don't go past that with aftermarkets, not a big deal IF YOU KNOW AHEAD OF TIME. PST denies it "never had an issue". The OE's on my Dart I recently had no problem cranking 130 on those and they're a size smaller than B bodies that are spec'd at 140.
jlatessa
Thanks everyone, 140 it is.
They are OE so let's hope....
Joe
