She's a squirter
Started by OzCharger69, April 25, 2021, 02:59:29 AM
OzCharger69
Apologies for the topic subject but I have this annoying problem. When I go hot in and out of a corner the window washers spray a decent burst of water on the windscreen. It is definitely not an electric short because I disconnected the washer motor and it still did it. It looks like the water gets thrown from one side to another in the reservoir.
Is this a common problem. Maybe I'm missing a one way valve along the rubber hose.
Fluid sloshing in the tub most likely.
Todd Wilson
cdr
Mine does it when I nail the throttle LOL, G force does it
Kern Dog
I had one when I was single. I was not all that amused. No thanks.   :eek2:
Back N Black
Quote from: Kern Dog on April 25, 2021, 12:36:40 PM
Did she pee in your bed and call it a squirt?  :rofl:
Kern Dog
Maybe....
Every session required a cleanup. You don't want her on top either.....her piss in your asscrack... :eek2:
OzCharger69
I knew this would go south, my bad.
I ordered some one way valves and will see how that works. Technically I could have just stuck one way valves from the fish tank aerator. which I have lying around
70 sublime
Quote from: OzCharger69 on April 27, 2021, 03:37:08 PM
Umm your one way valve will not work
You have to put the valve in the direction to let the washer fluid out so how is that going to fix anything ?
How many times do you ever use the washer feature anyways ?
More or less often than ripping around corners to make it leak out onto the windshield ?
Leave the tank empty  :2thumbs:
426HemiChick
Hi OzCharger,              28 April 2021
Not your fault. You have to consider the source.
An old saying sums it up quite well:
Better to remain silent and be thought a fool, than to opens ones mouth and remove all doubt.
Best Always
426 Hemi Chicks
Veteran - US Navy  Ex-Smoker (05 Mar 69) 55 years, heading for 100, 45 to go. Still lots to learn, lots to make up for. Weren't no angel. Fugitive from Southlake TX's Kangaroo Court
OzCharger69
Quote from: 70 sublime on April 27, 2021, 09:10:27 PM
The valve in itself creates some  drag which I was hoping would be enough. Tthe washer is rarely used but if it's a long drive through country roads you get heaps of bug splatter.
just had a crazy thought  , have you got the factory filter in the washer bottle ? no filter might cause water slosh & false water out the hose  :shruggy:
OzCharger69
