Which Antifreeze?
Started by frank1966, February 17, 2021, 03:23:51 PM
frank1966
Autozone give me 10 choice, 30 dollars for mopar antifreeze all the way down to about 8 dollars for peak!
https://www.autozone.com/antifreeze-radiator-additives-and-windshield-wash-fluid/antifreeze-coolant?filterByKeyWord=antifreeze&fromString=search&isIgnoreVehicle=false
Which is preferred? Mopars purple?
70sixpkrt
I've always used the 50/50 Prestone.
dual fours
In the Charger 50/50 Prestone here also, at least 2 gals. extra in the trunk for sure. If I blow out something or cook over at least I do not have to find water.
In the '74 Jeep CJ, 1 extra gal.
I still have brass and copper radiators in both.
1970 Dodge Charger SE, 383 Magnum, dual fours, Winter's shifter and racing transmission.
26 END
J25 L31 M21 M31 N85 R22
VX1 AO1 A31 A47 C16 C55
FK5 CRXA TX9 A15
E63 D32 XP29 NOG
flyinlow
The $30 Mopar stuff is for new cars.  50/50 Prestone  concentrate is what I use. The pre diluted is fine and more convenient . Unless you wipe your Charger off with a diaper every night ,they are not that sensitive to brand.
frank1966
Thanks, going with Prestone 50/50!
chargered
Can you use the Prestone in the new 5.7 Hemi's as well?  Don't like the orange stuff in the new cars......gets kind of coagulated and nasty after a while.
I buy the full stregnth antifreeze and mix it myself.  Not much for paying the same price for half water.
If its iron heads, basic green. If aluminum, gold.
frank1966
What's the purple in molar antifreeze which is a lot more money?
flyinlow
Quote from: c00nhunterjoe on February 21, 2021, 01:29:52 PM
  So for my Edelbrock  headed 440 casr I need more expensive antifreeze?
70sixpkrt
I have Eddy heads and still use green Preston 50/50.
What about the lasts forever stuff Jay Leno uses?  :scratchchin:
frank1966
Quote from: b5blue on February 22, 2021, 09:31:37 AM
If it really lasts forever, the company would go out of business
