Diff calculus
Started by Duran, February 15, 2021, 06:24:17 AM
Duran
Hi guys
I am about to embark on a rebuild of my 8 3/4 and am already confused
I have a big feeling I have already bought the wrong gear so please can some one set me straight
I ve purchased a new Posi track to suit 30 spline axle
I ve got a new ring and pinion set for 39 11 teeth 10 spline &
I still don't know what spline my axles are or how to tell (do I just count the number of teeth?)
Sorry guys I m lost here
AKcharger
I've always farmed out my diff work, not rocket science but to me money well spent
Quote from: Duran on February 15, 2021, 06:24:17 AM
The casting number on the lower left side of the third member tells you what gears you need, last three digits are usually 741, 742 or 489; the difference is the pinion shaft diameter. 39-11 is a 3.55 gear set.
All factory 8 3/4" axles are 30-spline. The yoke spline can be determined by the hex of the yoke nut, 1 1/8" is 10-spline while 1 1/4" is 29-spline.
The FSM is your best guide for the setup procedures.
Duran
That does shed some more light for me
And I did check my housing it’s a 489
also just checked my yoke nut which was 1 1/8 so a 10 spline
so i have a feeling i might have assed it and got the right gear as my new gear and spline are for a 10 spline woo hoo
The 10-spline pinion was available in all three housings, you need to measure the pinion stem diameter to determine if you have the correct gear set. A 489 pinion stem will measure 1 7/8" next to the gear. What's the brand/part number of the gear set?
These are the pinion differences between third member case ( aside the spline count ):
http://www.moparts.org/Tech/Archive/axle/1.html
Also 489 uses a conical collapsible spacer for bearings preload
