Cross ram intake
Started by 70 sublime, November 16, 2020, 10:10:38 PM
70 sublime
Just for the sake of argument would this fit on a 383 and clear the inner fender on a second gen Charger ?
Think I have seen this on a second gen Charger before but a 440 and they had to notch the shock tower to clear on one side of the car
Saw it listed locally
Description
1960's Chrysler Long Ram intake, for big block Mopar, comes with intake, block off plates and cross over tube.
If you buy that type of manifold, you'll want to get the complete setup, linkages and all.  Gets pretty pricey
RiverRaider
My first Charger was a Stock Car.
6pkrtse
I have always wanted to build a twin turbo set up using these.
1963 Belvedere 413 Max Wedge
1970 Charger R/T S.E. 440 sixpack.
1970 Challenger R/T Drag Radial 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Road Runner 383 4 BBL
1974 Chrysler New Yorker 440 4 BBL
1996 Dodge Ram 2500 V-10 488 cu in.
2004 Dodge Ram 3500 CTD Dually 6x6
2012 Challenger R/T Classic
70 sublime
After looking at the 440 set up pictures with these on it and how much they had to notch the inner fender I would think a 383 being less tall and less wide would make matters worse
Think I am going to pass on this foolish idea  :2thumbs:
GT
Quote from: 6pkrtse on November 17, 2020, 12:39:38 PM
Search for "Wawazat", a twin turbo cross ram 61 Belvedere.
https://www.youtube.com/watch?v=N5udjUXR7Fo
1970 Dodge Charger ==> V10
2012 Charger SRT8
sy440m
got one on my Daytona clone
70 sublime
sy440m
HPP
They are big torque producers for lower rpm use. Would be a great addition to a truck for towing. While impressive looking, they suck for horsepower production and high rpm breathing compared to other more conventional manifolds.
ACUDANUT
Seems like a very long path, from carb to cylinders.  IMO it would decrease power.:scratchchin:
If they were so great, why did they only last a few years.  :shruggy:
greycharger
As a kid, I found a stack of old car mags on a neighbor's garbage can. One mag had a write up of the new D500 with a Sonoramic 383. Chyrsler said it was like a free supercharger. The intake charges come in pulses that pile up in front of the intake valves waiting for them to open. The test in the 1/4 mile had a 0-30 time of 2.8 seconds with an open differential. Don't remember any of the other times. Even as a kid, I thought it odd that the tests were conducted with four men on board.
I guess being the setup from an RB block, still getting the full assembly the carb linkage ( if not other parts too ) will be a problem due the diff lenght between them on a B block :shruggy:
odcics2
Quote from: sy440m on November 18, 2020, 08:04:04 PM
Noticed these are the "short" long rams! They are not split the entire length of the runners.
This moved the power range up.   :Twocents:
HPP
you could always model up something like this:
cdr
