Battery group
Started by duckmanreno, November 09, 2020, 12:26:03 PM
duckmanreno
69 Charger 383 4 speed AC car.
What is the correct battery group to use in this car? Not worried about original looking, but what fits the tray correctly.
Thanks Joe
22 Ford F-150 5.0 super cab FX4 hunting rig and tow vehicle
92 Toyota Tercel.  Commute Car
69 Charger 383 4 speed project car.
73 Boston Whaler Montauk
A bad day hunting beats a good day at work!
Both the Group 24 and Group 27 were available, with A/C I would expect to see a 27.
Mopar Nut
Measure your battery tray.
gtx6970
Quote from: Mopar Nut on November 09, 2020, 03:20:44 PM
battery tray is the same regardless of original battery. I would suspect a 27, But no way to say for 100% certainty unless you have the build sheet
Mopar Nut
Quote from: gtx6970 on November 09, 2020, 05:27:35 PM
There's two different size battery trays.
6bblgt
all '69 Chargers had the same battery tray
that being said a 383 car had a group 24 battery as STANDARD equipment (a group 27 battery was a rare OPTION and most are found in cars originating in cold weather states or north of the border)
440HP & HEMI cars received the group 27 battery as it was STANDARD on a R/T
FYI - the A12 440+6 Super Bees & Road Runners had group 24 batteries STANDARD  :scratchchin:
6bblgt
of the ~65,000 US spec. V8 1969 Chargers (XP29): ~2,400 (~3.7%) were OPTIONED with the $8.40 group 27 battery "F25"
duckmanreno
Thanks I learned something today!
I will measure battery tray to double check. Car is not at my location.
duckmanreno
Well the group 27 battery fit the tray perfect.
Never found a build sheet for my car. Assume it was an option.
Quote from: Mopar Nut on November 09, 2020, 09:50:14 PM
Eeeeehm... not
Mopar Nut
Quote from: Nacho-RT74 on November 22, 2020, 02:42:10 AM
Eeeeehm... not
My 69 Charger came with the larger tray for a 27 group battery. My 68 Charger came with the smaller tray that would only fit a 24 group battery. I don't think anybody replaced the 68's. Both were rusted from the acid.
mmmm, maybe just 68 and earliers deal?
6bblgt
it takes a special person to keep coming back with "but mine was different" with no supporting evidence   :brickwall:
part # 2530994 is the original and ONLY factory battery tray for ALL 1966-'69 b-bodies & 1967-'71 Imperials
Mopar Nut
Quote from: 6bblgt on November 22, 2020, 01:45:24 PM
So special needs person what else came on my 68 since you know so much about my cars?
1968 parts book shows only one battery tray for B-bodies...same one used on the Imperials.
Mopar Nut
Looking at the battery tray from that part number mine looks different. Who knows my 69 could have a dealer installed tray. hence measure your tray.
My two cents worth here.....both my 66 Chargers have the group 27 larger battery tray, and my 70 Charger also has the larger tray as well
Bryan
