Getting car Track ready
Started by cdr, September 21, 2020, 07:51:05 AM
cdr
Well it was time to replace the MT Street R Drag Radials, 6k miles on them & they had become egg shaped, I guess I should have been lifting the rear when parked in the garage, especially after a long drive in the summer when they get VERY hot, I went with the same 325-50-15 but in the Hoosier brand DR, they seem VERY soft to the fingernail, so now waiting on a cool weather Track rental day, it is still pretty warm [HOT] here in Southeast Texas, so the next time out will be testing the new 4.10 gears it had 3.54 before & the new Hoosier's.
cdr
I also made a rear upper shock x member change, I bought a upper from RMS, that they use with the Street lynx 4 link set up, it is made to go in front of the Diff, I ordered mine without the upper arm welded tabs, turn it around backwards & install it in between the factory x member & it stands the shocks up more vertical. I had to remove my tail pipes for clearance, will have to do some modifications to the pipes , but will run with dumps for now, it is surprisingly quiet without them
cdr
cdr
cdr
BSB67
Looks great Charlie!  Can't wait to the see results
11.68 @ 120.2 mph
67440chrg
It looks good let everyone know how it does.
WHITE AND RED 69
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
cdr
Thanks Russ & everyone, still waiting on the weather to get a little cooler, drove a 65 mile trip to a car show, this is the last picture that my car will look like this, my car will be a little different, aint no tellin what I am up to LOL :)
birdsandbees
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Kern Dog
Looks like you're ready to go kill vampires.
(Blade)
70 sublime
Hmmmmm  :2thumbs: :2thumbs:
cdr
I am now in the Wing car club,,, well,,,,,,,,,,,almost 🙂  Got the Daytona ALUMINUM wing mocked up, holes drilled, got the wing washers in,,, paint tomorrow for the wing and then install, thank you Dane Gjesdal
for coming up with these wings, and your son Justin Gjesdal
did a very nice job on this wing, it's like Christmas for me
cdr
cdr
cdr
birdsandbees
Well aren't you full of surprises!!   :yesnod: :2thumbs:
70 sublime
I bet it hurt just a little to drill the first hole  :icon_smile_wink:
cdr
Quote from: 70 sublime on October 12, 2020, 06:21:39 PM
The drivers 1/4 was no problem it is the original one, the Pass side I put on, & all 4 holes was very PAINFUL LOL
cdr
Still got to finish the trunk braces but got everything pretty much mocked up, the charger is now a wing car except the nose & rear window LOL.
cdr
cdr
cdr
TexasStroker
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
