mirror differences
Started by ht4spd307, August 20, 2020, 06:00:55 PM
ht4spd307
Hello all just wondering if the left hand and right hand mirrors are different sizes as i wanted to purchase a R/H mirror and noticed the depth being different to mine is this a year variation or just as it was ? i'll try and add some pictures later once i work it out how too
ht4spd307
ht4spd307
ht4spd307
wow those photo's worked out real nice Lol  anyway you get the drift the original left hand one is about 17mm and the right hand one is about 28mm at the head is this normal for a L/H mirror
cdr
Quote from: ht4spd307 on August 21, 2020, 04:59:26 AM
yes that is correct
cdr
cdr
ht4spd307
Is that r/h a factory fitted mirror ? does it have a date code on the glass
cdr
Quote from: ht4spd307 on August 21, 2020, 10:10:44 AM
no its not, I also put a fish eye mirror on it so I can actually see cars next to me LOL, I got the mounting dimensions from this forum
ht4spd307
Thanks CDR for the reply I'd like to hear from someone who has a factory fitted one if it's the same or if there is a size difference hence the reason i asked CDR for a date code as all the ones i'm finding are date coded later
cdr
Quote from: ht4spd307 on August 21, 2020, 07:30:16 PM
I bought mine as a factory replacement  pair , driver side adjustable from inside. the none remote mirrors are different
DAY CLONA
Quote from: ht4spd307 on August 20, 2020, 06:00:55 PM
You'll find that in most mopar dual mirror applications the passenger side mirror doesn't quite match the shape/profile of it's mate, reason is the passenger side mirror requires a greater degree angle of the glass mirror to be properly seen by the driver... here's some extreme cases of mopar mirrors, 1970 E racing body and 1970 B body/71 A body Racing mirrors
Mike
DAY CLONA
This is a matching E body racing set for 1970... it often confuses first time buyers/user that something is wrong, but this is how the factory did things
Mike
It would actually make more sense for cars to have the passenger side mirror larger than the driver side one.  The driver's eyes are much farther away from the pass side.
ht4spd307
Thanks guys for the reply's but have another question is the R/H mirror mounted  in the same location as the L/H
