Not charging
Started by Brightyellow69rtse, June 30, 2020, 08:03:35 PM
Brightyellow69rtse
Hey guys After a couple year hiatus I think I got all my brake issues sorted. Tomorrow will be the test drive for sure but now my alternator isn't charging. It's not the alt I tried another one and Didn't make a difference. The car was charging fine. All the wiring is new. I'm wondering if something coulda got knocked off during the replacement of all the brake lines. Literally every single piece of the brake system was replaced. Any suggestions on where to start? Thanks!
BLK 68 R/T
voltage regulator and connections. also check the bulkhead plugs.
why you say is not charging ? what reading do you have on ammeter ?
Brightyellow69rtse
Voltage at the battery was 12.5 with the engine running.
Today I ran 12v power to the field side on the regulator for test purposes. then the alt was charging the battery. So I'll order a new regulator.
blakemon
Have you tried checking all the grounds?
