Working on Chargers not cheap What was last thing you did for less than $100 ?
Started by 70 sublime, May 11, 2020, 09:56:44 PM
70 sublime
Buying parts or upgrades on these cars never turns out to be inexpensive
So what have you done on your car that cost you less than $100 out of pocket to do ?
Getting a tank of gas does not count  :icon_smile_wink:
I got a new gas filler neck lock but it ended up costing me more than $100 so does not count
I guess I got 4 tires that were already on mag 500 rims balanced for $15 each cost me $60 counts  :2thumbs:
Looking around on the local classifieds I came across an ad for a scat pack bee emblem
Hmmm what could I do with this
My grill is missing a couple slats so I thought it might look ok sitting on my grill
Now that I did it it might look more like one of those large killer hornets stuck in my grill
The bee cost me $23 each plus $2 shipping
Yes it was snowing at my house again this morning  :brickwall: :brickwall:
kab69440
Turned a set of a free wheel covers into centercaps for my vintage Turbo-Vecs.
Imagination was given to man to compensate him for what he is not;  a sense of humor to console him for what he is.      Francis Bacon
WANT TO BUY:
Looking for a CD by  'The Sub-Mersians'  entitled "Raw Love Songs From My Garage To Your Bedroom"
Also, any of the various surf-revival compilation albums this band has contributed to.
Thank you,    Kenny
Jesus drove a Honda. He wasn't proud of it, though...
John 12: 49     "...for I did not speak of my own Accord."
Mytur Binsdirti
chargermick
Dashboard voltage limiter. Personally, if a repair is less than $300, I feel lucky.
green69rt
Kern Dog
Since I am buying stuff used for my Jigsaw project, I have made some good deals.
Gas pedal and center dash piece  $50
Firewall brake stiffener plate and Charger grille emblem $35
Engine side wire harness  $60
10" rear drum assemblies $101
Front brake calipers $46
Wheel bearings and seals $58 (New...I'm not a total hack !)
krops cars
67440chrg
RallyeMike
The last two things I did : Radiator shroud and battery tray each under $100
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
CDN72SE
MOPAR 318/340/360 Small Block Intake Manifold Bypass Hose Nipple OEM - $25.70
OEM MOPAR Power Steering RETURN HOSE Plymouth Dodge Chry '67-79 383 440 340 Hemi - $17.88
MOPAR Power Steering Pressure Hose 68-72 Saginaw A,B,C,E-Body 318-340-440+ - $37.59
Upper rad hose - $95
Lower Rad Hose - $69
1970-73 Mopar 318ci 340ci Charger Reman Saginaw steering pump pulley - $100
NOS Mopar Crankshaft Pulley Bolt Screw Kit 318 340 360 440 383 426 Hemi Dodge - $18.69
Got more on the way; the exchange rate plus shipping to Canada is killing me. Hopefully there will be some kind of Memorial Day sales going on.
1972 Charger SE
MoparMike68
BLK 68 R/T
cdr
Quote from: 70 sublime on May 11, 2020, 09:56:44 PM
I put the Scat Pack Bee's on my wings
70 sublime
62dodge
I looked at my Charger for 29 seconds, if i look at it for 30 seconds it starts pulling Hundreds out of my wallet
cdr
Quote from: 62dodge on May 13, 2020, 06:52:56 PM
LMBO !!! Truth ^^^^^^^ :)
smithenhiven
I bought some LED bulbs for my hood turn signals, I think they were like a buck a piece.  Probably the cheapest "part" I bought for the car.
F8-4life
I thought Mopar was expensive... untill I tried to replace one of the dash switch buttons light of a P38 Range Rover
https://rimmerbros.com/Item--i-STC1878
They can be found cheaper:
https://www.brit-car.co.uk/product.php/92604/1763/upper_facia_green_bulb___holder_assembly___discovery_1_1989_1998___range_rover_classic_1992_1994
but also more expensive with "free shipping"
https://www.ebay.es/itm/Original-Land-Rover-Discovery-1-2-Verde-Bombilla-Soporte-para-Interruptores/323049399395?hash=item4b373ea463:g:owcAAOSwNmVadQt~
( the shipping for this could be anything between 5 to 10 GBP between UK and Spain. Insane )
Sure I just will proceed to find just the bulb and will replace that keeping the socket and green cap. US$3 for 5 bulbs, plus US$3 for the shipping between France and Spain. Its a bit tricky just to do the bulb change but not really hard.
I could find the bulb locally mostly sure at a local hobby trains shop or electronic shop, but due the lockdown that's not posible so just clicked on line
Stringbender
Hahaha some hilarious replies! Just Did a 727 fluid an filter change for under $100. I guess it really depends on what point the cars at. My cars a driver I've had, an had running a little over a year. Being on a shoe string budget I'm always doing ANYTHING I can to improve it for under $100. Some of my most rewarding improvements have been Free. For me It's usually summoning the "will"  to climb under the dash (Again usually) to track down some intermittent issue. Or pull the distributor out an apart (countless times lol) to see if I can squeeze any more "performance" out of it. You're right though working on these things is expensive. The Chevy guys at my local cruise hate how people walk right by there shiny Chevelle's to look at my primered "Dodge". But Damn am I jealous of how cheap an Plentiful their parts are!
TexasGeneral
Quote from: TexasGeneral on May 17, 2020, 04:53:16 PM
I paid $1 USD to put a little air in the right rear tire :icon_smile_big:
Which in its own way could be considered too much, seeing as how we used to be able to get air for free.
