Best Brake Line Supplier
Started by Ghoste, March 18, 2020, 05:12:53 AM
Called Inline Tube yesterday and they wer trying to set me up with a kit for a Plymouth, which I assume is shorter because of the shorter wheelbase.  Fine Lines does not seem to have one for my application.  I need one for a power disc brake, left ported master cylinder, Dana rear with distribution block, metering valve and rear drum hold off (proportioning) valve.  And I am assuming the proportioning valve is the one that determines one or two piece rear brake line?
Double check everything my 70 has a 68 (8 3/4) rear axle and the vent tube (That holds the T fitting.) is in a different spot. That changed how long L & R lines are! They asked if my front lines were above or below the subframe and somehow I got that wrong. (After swapping to disk.)
birdsandbees
Remember the "shorter" wheel base is created by the front leaf spring hanger, not the body!
Got all of mine from "rightstuff".
https://www.getdiscbrakes.com/
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
I have to admit that I don't understand.
birdsandbees
The 1" difference in "wheelbase" between Plymouth and Dodge is because Dodge uses a 1" long leaf spring hanger at the front, which moves the rear axle back 1". Has nothing to do with body and frame length.
Okay, so the axle would still be 1 inch further away from the proportioning valve though would it not?
70 sublime
Quote from: Ghoste on March 19, 2020, 05:14:09 AM
Different rubber flex line ?
