i started it,it ran and then.....
Started by 7273chargerguy, May 14, 2006, 06:32:59 PM
7273chargerguy
it spewed out all my oil! i started it for the first time(my newly rebuilt 318)it ran for about 30 sec when i noticed all of my oil had came out of the oil filter.i had had a problem with the oil filter housing(the machine shop forgot to put it back on)my question is are you supposed to use gasket sealer on the rubber gasket that goes inbetween the block and the oil filter housing(and if so do you put it on both sides?)and how much do i tighten the screw in nozzle that you screw the oil filter into?i
"yours it not to question why,yours is just to do or die."
N. ever A. gain V. olunteer Y. ourself
they can be tough to seal , a sealer is a good idea , I don`t have e torque spec for that though
