Positive camber
Started by Polygon, October 03, 2019, 01:55:41 PM
Polygon
ok, Tire are wearing out on the inside. Positive camber. I do have the FSM.
And...eventually, this year, I will tackle the whole front end. But for now, (Since I have never done this before), is there a handy YouTube video, to guide me? Special tools?
John
PS, on vacation! When I get back, got a Mech buddy with a shop. So, we will put it up and take a complete look. But for now, maybe I can do an adjustment.
www.lostinspaceforum.com
If you like the old TV show, Lost In Space, check out my page
alfaitalia
Too much toe out will also wear the inner edges.
  Offset upper control arm bushings may be needed. Crank the adjusters all the way out and set ride height per FSM is about all you can do for now. Worn ball joints/bushings can make it worse.
cdr
Quote from: Polygon on October 03, 2019, 01:55:41 PM
John
wearing on the inside is neg camber and OR toed out
Polygon
