LED Taillight bulbs
Started by Tmb84, September 20, 2019, 05:51:01 PM
Tmb84
is there any led bulbs there will fit in the original socket? -70 Charger
70' Charger 383 -top banana
71' hemicuda Sox&Martin "tribute"
ACUDANUT
 Yes, if you go to a auto parts store, they will have a replacement for the 1157.
Tmb84
reason i ask is because the left side is brighter than right side and i dont see any reasons why it is like that. i was thinking maybe led bulbs would eliminate the problem.. ?
WhiteOnGreen
Quote from: Tmb84 on September 20, 2019, 10:03:34 PM
May be wiring resistance? melting contacts?  :scratchchin:
Canadian1968
It could be an older bulb compared to the others? Or you could have  a connection problem of some sort .
LED do come with other problems especially with the dual inputs on the 1157 ( one for brake and one for running lights ) The LED will give fwed back threw the other input and can cause your side marker lights to come on as well. Also there is thr flasher problem as well..Since the LED draws so little current it's might no pull enought current to activate the flasher or cause it to hypeflash. I tried the LED route and had to many problems . Went back to the orginal style .
Tmb84
okey, thanks. new bulbs didnt help at all. i grounded them with no luck. the wires looks ok. i hate electrical issues
The rear harness connects to dash harness under the kick panel behind the emergency brake pedal. look for a crusty connector.
