A/C O rings
Started by roger440, August 08, 2019, 03:30:02 PM
roger440
Not sure if this is the right place, but does anyone know of a "kit" of all the correct o-rings for the A/C system (69 440)?
Or us it just by an assortment of modern metric ones and make them fit?
1969 Dodge Charger RT/SE
1970 Plymouth Roadrunner - SOLD
2017 HSV Maloo
2003 Holden SS Ute
1970 Triumph 2000 Estate, fitted Rover V8
1961 Standard Atlas
1980 Triumph Dolomite Sprint
1974 Triumph Stag
2003 Subaru Forester
GMP440
  Harbor Freight sells the plastic case set of o-rings.  Are you still using R-12 or did you convert to R-134?  Either way,  they sell both the black o-ring and green R-134 seals.
  Here they are:  https://www.harborfreight.com/search?q=o-rings
   Bottom right, you see the green R-134 seals.  All these sets are under $10.  Use the 20% off coupon for these.
