COMP Cams
Started by Rudderguy, April 16, 2019, 10:44:25 AM
Rudderguy
Good Day All,
Anyone have any experience in these brand of cams good or bad?
What type/model of cam from COMP would you recommend if rebuilding a 69 440 motor getting back to original as possible?
How do these compare to installing a Chrysler Cam for power etc?
Thanks for your help
rudderguy
Rudder Guy
XH29N0G
I have seen them discussed a lot and recommended a number of times.  I also have a custom grind from them in my engine.  My impression (but wait for some of those who are really informed on this site) is that they are reputable and make a decent product.
Or maybe it protects us.
justcruisin
I have had no problems with them, however, their xe/hl series can kick up a bit of clatter.  Their 268AH is probably a good grind for a stock engine but I have no experience with it.
69wannabe
The XE 268 is a good cam for a mild 440 build and it's pretty quiet operating too, the XE 274 is my favorite cam for a 440 but will need a small stall converter and it a lil bit noisy but a good powerful and torquey camshaft. I am running the XE 284 in my RB engine and it runs good but is a bit more noisy than I like it to be but it is pretty big in duration so it is what it is.
BLK 68 R/T
One thing I've learned on here about cams is that if you are going to run manifolds you want a cam with a 112 lsa or bigger in order to work well with manifolds. Seems like the majority of the cams are in the 108-110 lsa range. Something to keep in mind.
Back N Black
I'm running a Com cam  XE 274 and I like it. Makes just shy of 500 hp and over 550 torque. :2thumbs:
