What is holding this part on here?
Started by jefferson, January 26, 2019, 07:13:10 AM
jefferson
https://imgur.com/a/hTa66cc
On my 68, this part that ive outlined in black has come loose and wobbles, is it a clip of some sort, perhaps gotten bent over the years, or glue?
I can wiggle mine around and with enough force, probably pull it completely off, realised today when i noticed the gap as i was going over my car, im like WTF, touched it and it wiggled and was loose.
frustrated me. lol
hopefully just a clip or a spring, i didnt have enough time before i had to go to work to further investigate.
Cheers
68RT440
There are 3 studs on the back of that piece. If you go into the trunk you will see the studs coming through. The nuts holding that piece on either came loose or the studs are whittled away ( the nuts cut their own threads in the studs and sometimes after removal/ installation too many times there isn't enough material left on the stud for the nuts to hold tightly)
1968 Charger R/T, matching numbers 440/727, black with green top and interior, currently getting restored by me
jefferson
Thanks a lot mate
thought that may be the case.
Did NOT even realise it was a seperate piece to tell you the truth
Just thought it was part of the whole quarter.
The things you learn everyday
Cheers heaps man, very much appreciated.
dual fours
Don't break the studs off. That corner piece is a cast item. The nuts can be worked to make the cutting threads a smaller opening to grip/cut into the stud to stay on tight.
edit: Ok, the corners are being made now.
1970 Dodge Charger SE, 383 Magnum, dual fours, Winter's shifter and racing transmission.
26 END
J25 L31 M21 M31 N85 R22
VX1 AO1 A31 A47 C16 C55
FK5 CRXA TX9 A15
E63 D32 XP29 NOG
