Trunk lid alignment
Started by vita, December 17, 2018, 08:47:48 PM
vita
Guys,
Working on getting the back end of the charger squared away. After getting on a bunch of the metal screwed into place, we've noticed a few issues with the trunk lid.     Pictures attached!
https://ibb.co/pZ8s11d
https://ibb.co/8D57zpX
Whats the proper way of getting this to line up a bit better?    Any tricks ya'll have to get this to play nicer?
hemi-hampton
Is the Trunk latched closed. Why are pics sideways? LEON.
cdr
I loosen up the hinges & latch,close the deck lid align the deck lid & tighten up the hinges & latch working through the missing tail lights it will get you very close, I also do this with no hinge springs on .
70 sublime
You should put the end caps on the 1/4 panel to line up with
Looks like you are trying to line up with 1/4 but then that will make the trunk lid too far forward
cdr
Mopar Nut
Stick someone in the trunk to tighten the bolts while you adjust the lid. Don't forget the end caps.
