Power steering pump
Started by q8charger, December 07, 2018, 05:58:59 PM
q8charger
Hello,
I have Federal power steering pump making noise when I push gas only on the straight road .
What is the problem ???
Back N Black
Check fluid level, loose belts and up down movement in the pulley.
q8charger
The level of the fluid excellent and belt so taut .
Bronzedodge
So the next step would be an output pressure check.  You'd have to make up some sort of gauge tee adapter for the pressure hose.  A better option might be a simple fluid flush - extend the return into a bucket and run until empty, stop immediately after to avoid a long dry run of the pump.  New fluid is cheap.
Mopar forever!
What kind of noise? (Squeal, groan, clatter) Are you sure it's the P/S pump?
