Main Bearing Sizes
Started by 68CoronetRT, August 19, 2018, 10:38:56 AM
68CoronetRT
Does the main bearings only come in .010 under sized? This would be on a 440, 78' block. Also a cast crank if that makes any difference. In other words, once you pass the .010 undersized point of a crank, is that it for the crank?
cdr
You can get .020 under. But for the cost to cut polish and rebalance, you could buy a stroker crank. I wouldnt run past .010 even on a street build.
Sealed Power (#5025M) and Mahle both show .030" undersized wide-flange main bearings.
It's pretty common nowadays to grind the RB mains 1/8" under to fit the B block with no epidemic of failures.
