1969 charger ignition, door, trunk lock cylinders
Started by jwells1993, December 22, 2017, 06:15:48 PM
jwells1993
keep on keepin on
The 69 ignition switch is different. It's on the right in the picture so you can see the lock cylinder is likely longer and bigger around. The left side is a 68 but Chrysler used the same one from 62-68. The 69 was a one year only part as the ignition moved to the steering column starting in 1970 for all cars. The rest of the locks in that kit are probably the same.
jwells1993
Oh ok thank you that explains why the 69 kit is pricier haha
keep on keepin on
