Delay shift
Started by q8charger, November 25, 2017, 08:19:20 AM
q8charger
Hello,
I have problem with the delay shift Automatic transmission 727  .for example if the transmission was on P than I moved to the D it take 3 to 5  Seconds for the moveing car  seam things from P to the R . Anyone know what's The reason for the delay ???
flyinlow
Check the fluid level. Idling in neutral, warmed up. Idle speed normal.
Could be a transmission filter that is dirty restricting fluid intake to the pump. Drop the pan , inspect and replace the filter.
q8charger
Quote from: flyinlow on November 25, 2017, 01:33:05 PM
Do you suggest using this
https://www.summitracing.com/parts/dcc-4120461
Is there always a delay when shifting out of Park or only when it's been sitting a while? Could be normal converter drain back, try shifting to Neutral for a few seconds before selecting other gears.
