Help needed choosing an oil pan
Started by timmycharger, November 14, 2017, 09:56:11 AM
timmycharger
I am currently running a Moroso 7Qt deep pan with a 1/2 pickup.  I have a rear main seal leak that I need to address and wanted to swap out my existing pan for something more stock appearing and not so low hanging while I am down there.
I tried searching for the correct one but got overwhelmed with part numbers  :eek2: so instead of re inventing the wheel, I figured I'd ask here.   I am looking for a 440 HP/440 six pack pan that will fit in my 68 along with a matching pickup. The pickup needs to be 1/2 as my block is modified.  I want to re use my windage tray that I was using if possible.
Any feedback is appreciated as always.  :cheers:
cdr
Mancini racing have a 68-69 Hemi pan & a 1970 hemi pan , 6qt both will work
chargerbr549
B5 Charger has a Hemi pan listed in the for sale section here that should work for you.
http://www.dodgecharger.com/forum/index.php/topic,130487.0.html
timmycharger
69wannabe
Quote from: cdr on November 14, 2017, 12:11:29 PM
Was also going to say Mancini racing has the one you need but cdr beat me to it!!! I got my 6 pack pan from mancini and it works great.....
timmycharger
Quote from: 69wannabe on November 15, 2017, 10:18:04 PM
:2thumbs: Member B5 Charger hooked me up with the pan from Mancini.  :cheers:
