74 charger grille
Started by busteed, April 28, 2006, 08:58:36 AM
busteed
Is there actually a driver side and a passenger side grille?  Or are they both interchangeable?  I need to replace the driver side, I have a broken fin or two.  I see them on e-bay, somethime they are listed for a particular side and sometimes not.
DFS68_Charger
The grille halves are not interchangeable from side to side. I may have a good driver side grille if interested.
DFS
Charger1973
Yep,  both sides are different.  Usually they are not too expensive though.
both are different yes.
73 and 74 are the same
SEs and rest are not the same but fit the same since difference is only on exterior looks... SEs with chromed edges beside the red/chromed insert and rest painted on argent and black.
Can you ry to fit one on another side ?, definitelly yes since a buddy's mine did it for a while he found the right side,  I think changin plastic fasteners of position... brackest have different holes to instal fasteners on different position and match with grilles BUT difference will be slightly noticeable since grilles gills on right position are flat and reversed are steped. Also beams holes are different high but nothing to worry... maybe just a milimeter difference.
