Do you have a 4 core Champion aluminum radiator in your 68-70 Charger?
Started by Blakcharger440, August 06, 2017, 02:14:14 PM
Blakcharger440
I am planning on buying a Champion 4 core aluminum radiator for my 70 Charger RT with 4speed. Does anybody have a part number for one that will work for my car?
Do any of you have Champion radiators and will the factory shroud work with it? I have a 26 inch opening.
Any feed back as to if these radiators are any good?
randy73
I have the Champion in my 73, I believe it is more important for the outlets in the radiator to match up to the outlets in your engine. Find the radiator with the right bolt pattern and the radiator is on the same side as the engine outlet and so forth.
I have been known to be wrong, but when I asked, that is what I was told.
kokxville
This radiator works great in my 69 rt. Like Randy73 says make sure that the outlets match your old radiator so your hoses will fit. :cheers:
1969 Charger R/T 4 speed A33 Track Pack.
1967 Dodge a108 360 Magnum. Daily driver
1969 Dodge Charger"the car you can take your kids in to school on a friday,go shopping on a saturday,dragrace on a sunday and go to work on monday"
fy469rtse
me also, i have the big three core , equal to the four
543 stroker
victor heads, big comp , cools my engine easily  :2thumbs:
Blakcharger440
I am planning on buying the 4 core MC375. The outlet and inlet seem to match as the top hose is on passenger side and the bottom hose is located on driver side. My radiator core opening for my car is 26 inch.
Were you able to mount your factory fan shroud on your radiator?
justcruisin
I have a CC375B which is the same as the 4 core you are looking at but with three rows of .75" tube instead of 4 rows of .63" tubes. I bought a P2998326 shroud for it, it will bolt up but there is a gap between the radiator and the shroud, the mounting points are to far rearward on the radiator so the answer is - if you have that shroud - no, it wont, the gap makes it useless. However, it looks like it will fit with some mods and work well, just haven't got to it yet. But it will not fit the same as OE.
Blakcharger440
Quote from: justcruisin on August 07, 2017, 03:49:04 PM
How big of a gap was it? Is there a lip on the shroud where it bolts mates to the radiator that you could put some foam to close the gap?
What car and engine is your set up on?
justcruisin
The gap is 1 inch, top and bottom with the sides of the shroud sitting on the mounting point of the radiator. Yes you could put a spacer in to take up gap but the shroud only has a flat surface of about 1/4 inch on the top and bottom where it faces the radiator - probably look a little ugly. What I intend to do is alter the shroud so that it fits under the mounting points of the radiator, that way it will sit flush all the way around. I imagine it will need some support at the top and bottom at the middle point to prevent the shroud warping. I will wait until I have the engine in the car so that I can check fan/shroud location first. Car is a 71 R/T.
werner
Have a 4 core in 69 Charger with 528 hemi work good even with no shroud. Heats up around 210 it stop and go traffic but cools down immediately once you start moving. I tried stock plastic shroud but fan sits too far away from core of Rad and tips of blades are not in shroud.My enginedoesnt sit level so gap at bottom is 2" and top like 4". Im going with a Derelle shroud and 2 electric fans shortly
1969 dodeg charger, 528 hemi ,Tko 5spd.
xx29440charger
Blackcharger440, did you put the Champion 4 core radiator in your car and how is it working and how was the install?
70sixpkrt
