cleaning hemi 2x4 intake
Started by werner, July 27, 2017, 11:20:34 AM
werner
other than glass beading what do people use to clean their intakes to make them look new again ? Its not corroded just dirty.
1969 dodeg charger, 528 hemi ,Tko 5spd.
alfaitalia
Can't beat vapour blasting for those sort of items if you want the very best finish. Also wont leave any debris (such as glass beads or abrasive sand) jammed in tight areas to fall into the motor at a later date. Can be difficult to find people who have the equipment...depending on where you live...at least it is over here.
BSB67
Clean it then paint it.  Otherwise it will look like pooh again pretty quickly.   :Twocents:
11.68 @ 120.2 mph
timmycharger
Quote from: BSB67 on July 27, 2017, 05:45:44 PM
Agree with this. I painted my six pack intake that was originally cast aluminum since it just wouldn't come clean again.  I think I got engine specific paint (rattle can) and it still looks new 2 years later.
BSB67
cast aluminum paint.  The dyno operator did not know that the intake was painted.
11.68 @ 120.2 mph
werner
THAT LOOKS GREAT. WHERE DID YOU PURCHASE THE PAINT ? I TAKE IT IT IS HIGH HEAT AS WELL ?
DAY CLONA
Quote from: alfaitalia on July 27, 2017, 05:37:58 PM
"vapour blasting" is nothing more than water and GLASS BEADS....
I have always just used rattle can engine paint myself and I've been happy with the results.
