Chrysler Corporation On Vin
Started by JMF, July 24, 2017, 04:46:33 PM
JMF
Did all vin tags on the dash of a 68 Charger have the "Chrysler Corporation" on them ? I've seen a couple without where it's just the vin on there, is this a car to be avoided do you think ? Also do all Challengers have the "Chrysler Corporation" on the dash vin ? Thanks
JMF
Please see pic below, was the "Chrysler Corporation" just printed on there originally in ink or something ? Or stamped ?
F8-4life
The vin tags lacking the chryco stamp have just had there dashboards and or vin tags painted over.
Nothing to be concerned about really, although it is just one less aspect of originality lost.
dual fours
What the hay did they spray on the dash?
You can see where the spray is missing on the forward side of the lettering and the rivets.
If this is your car, as in the owner, take very little Acetone on a rag and see if the orange peel paint will come off on a corner of the VIN tag, if it does, work your way over the tag and hope the original black base coat and the white printing stays on. If the white printing goes away also, someone (ECS) makes the decal to replace the white printing.
You would want to have someone looking though the windshield as you remove the crap, so they can tell you what is happening.
It looks to be applied from the inside forward, so it would be a side ways paint job over the tag as apposed to a straight down though the window opening paint job, sideways being maybe easier to remove, the paint may not be applied as heavy.
I wonder if it is this paint? https://www.oreillyauto.com/detail/dupli-color-3391/chemicals---fluids-16461/paint---body-repair-16614/paint---wrinkle---textured-18075/spray-paint/mx100/4268153/1969/plymouth/gtx
If this was done to the dash, I wonder what else was covered up? :scratchchin:
1970 Dodge Charger SE, 383 Magnum, dual fours, Winter's shifter and racing transmission.
26 END
J25 L31 M21 M31 N85 R22
VX1 AO1 A31 A47 C16 C55
FK5 CRXA TX9 A15
E63 D32 XP29 NOG
Lennard
Quote from: dual fours on July 24, 2017, 05:08:04 PM
It looks like bed liner or something.  ECS sells the correct Chrysler corporation decal.
http://www.ecsautomotive.com/productdesc.php?co=c&id=62
JMF
