Wheel Size help please
Started by skippychad, June 29, 2017, 11:38:46 AM
skippychad
my 69 charger is missing a spare tire.  Im not looking for an original , but rather something to use in case of an emergency...not a donut:)  My current front tires are P215/60R15 and the rears are P255/60R15. Trying to do a reverse conversion here I suppose...tire size to wheel size.   I know I need a 15 inch rim with a 5 bolt pattern. Not sure if any old rim of that size will do.  Im not sure of width or if it really even matters for a spare.  the axles are original if that helps.
VegasCharger
If you're looking for a quick fix or inexpensive fix, try finding a Chrysler 15" steel rim from a junkyard. Any midsize or full size car from the 80s or 90s should work. Any Dipolmat, 5th Ave, St Regis, Fury etc. Make sure it's 5 lug on a 4.5" bolt circle.
:cheers:
skippychad
the bolt circle...where is that measurement from?
skippychad
alright researched it...got it
