hood clearance
Started by charger_fan_4ever, June 13, 2017, 01:13:52 PM
charger_fan_4ever
Hello guys quick question.
I have a 70 440 with an edelbrock dual plane intake on it. Cant recall which one. I want to run a holley/pro form 750 mechanical carb just for tuning and ease of mind as i have ran one on another car for years.The holleys are just so reliable and easy to tune.
I also want to run the stock 70 dual snorkel air cleaner. My question is will the stock air cleaner/750 carb/aluminum intake fit under a stock 70 hood ?
I picked up a 70 intake just in case.
XH29N0G
It really depends what type of aluminum intake you have.
Or maybe it protects us.
mopar0166
i have a 69 and the dipple in my hood says no,
I used the bottom of a lowering air cleaner, on top of a 1/2 adapter to finally get clearance for hood and carb
just be careful,  I later used double sided tape on high point to see if I got clearance,  start slow.
charger_fan_4ever
Quote from: mopar0166 on June 14, 2017, 03:00:43 PM
Which intake and carb were you running ?
mopar0166
holly 850 dp, edlebrock rpm performer
