ac delete
Started by Shlep 68, April 10, 2017, 05:12:56 PM
Shlep 68
hi im wondering where i can get a ac delete bracket for a 1969 440 chrysler 300 as i cant seem to find one and some people say you have to change all thepulleys?
there is no "delete" bracket or pulley for the AC....you either have to mount the compressor, or change all the pulleys and water pump to change to Non-AC belt arrangement
Shlep 68
thats what i thought thank you
BDF
I thought there was a bolt on idler pulley that worked for this in place of the compressor seems like I saw a picture of it on a member's car?  :shruggy:
shortbox
Quote from: Shlep 68 on April 10, 2017, 05:12:56 PM
http://bouchillonperformance.com/products-pulleys
Quote from: shortbox on April 10, 2017, 09:56:58 PM
that's for newer serp belt systems....and the newer engines....won't work on his car
shortbox
Quote from: A383Wing on April 11, 2017, 04:59:00 PM
Give them a call. I got every thing I needed to do mine. They are very knowledgable
Quote from: A383Wing on April 10, 2017, 06:35:34 PM
Actually, there is (called a bypass pulley) but I can't remember who offers it.
ACUDANUT
You don't need to change water pump.  :yesnod:
Quote from: ACUDANUT on April 12, 2017, 04:24:04 PM
yea ya do....vanes are different size and different number of vanes for AC & Non-AC pumps
ACUDANUT
No you don't. But I guess my 50 Years of Mopars don't equal your 20 tears. :scratchchin:
Depends on the year; early A/C cars used the same pump for A/C or not but that changed around '69 when they overdrove the pump by 40% to increase the fan speed and this necessitated reducing the vane size to prevent cavitation.
Of course, some folks use the wrong parts and get away with it so that becomes the rule.
Quote from: ACUDANUT on April 13, 2017, 01:00:03 AM
Well, maybe you should check the parts books instead of your 50 years of wrong understanding of water pumps
the 66 parts book lists 2 different water pumps for all the big blocks
Part number 2448326 is for all big blocks without factory AC
Part number 2585384 is for all big blocks with factory AC
if you use the wrong pump, engine will overheat due to either pump not pumping enough water through the block, or the water pump will cavitate the water so fast it won't go through the engine
Non-AC pumps have 8 vanes and the vane diameter is almost the size of the opening in the water pump housing
AC pumps have 6 vanes and the vane diameter is about half of the non-AC pumps
not sure how much more explanation you require
pictures are below for your viewing pleasure
BDF
Quote from: John_Kunkel on April 12, 2017, 01:44:09 PM
This is what I was referring to in reply #3.  :cheers:
ACUDANUT
Well, I guess I got lucky. When I removed my a/c system I never touched the water pump and had no problems.  I can tell you I have had a couple of water pumps go bad in the 30 plus years I have owned it.  One water pump broke a bearing and the fan destroyed my radiator.
