489 case 3.55
Started by ACUDANUT, April 06, 2017, 01:51:46 PM
ACUDANUT
1,650 bucks from Randy's. ? WOW how prices jumped up.
Anyone have ideas where to find a cheaper, new and complete ?
RCCDrew
Have you tried Dr Diff?  :ahum:
Alaskan_TA
ACUDANUT
No, but 1,375/1,400 dollars still ain't cheap. Thanks though! :2thumbs:
Alaskan_TA
I pieced one together last year.
Used 742 case with good 3.55 gears (open).
Used clutch style sure-grip.
After the rebuild parts & bearings were purchased & I payed a local shop to assemble it, I was very close to what Cass charges for a fully assembled 489 with new parts.
Next time, I'll just go to Cass.
ACUDANUT
Quote from: Alaskan_TA on April 06, 2017, 04:56:43 PM
Who, what is cass ?
RCCDrew
I built one last year with a lock rite locker. Wasn't too bad.
Alaskan_TA
Quote from: ACUDANUTWho, what is cass ?
Dr. Diff has a first name.
303 Mopar
71charger_fan
By the time I priced gears, bearings, and factored in labor, I just bought a new 3.55 from Dr. Diff.
I THINK!!!!
get an used open diff with 3:55 and buy the carrier separatelly. Shouldn't be more than US$800 all together.
or get an used housing with any gear in it and get just gear set and carrier new. Shouldn't be more than US$900-1000
nevermind... it seems his prices also reachs around US$1500 once everything is built... but try a call, who knows.
I still think can be built in US$1000 rate: used housing ( 150 or so ) New bearing set with seal bolts and gasket ( 100 or so ) new gear set ( 200 or so ) new carrier ( 400 or so ) yoke and straps ( 100 or so )... shippings ( 40-70 )
dunno about a local builder
prices from what I have checked on ebay
another option:
http://caldwell-id.americanlisted.com/car-parts/mopar-875-8-34-489-323-sure-grip-1_25857147.html
its borg-wagner, not clutch but US$400 for the unit... add new bearing set if wanted and change the gears... ( US300 or so )
odcics2
I know a guy that has a 5.xx gear in a 742 case with a Detroit Locker in it for $500.
Ready to run, or swap whatever ring-pinion you want in it.
PM me if interested and I'll pass his info to you.
BrianShaughnessy
Sinnamon's 8 3/4 consists of a $125 open 3.23 489 from Craigslist and a $500ish TrueTrac from Summit and a bearing kit.
Kern Dog
Dr Diff is a business name. The MAN is named Cass Eslick.
ACUDANUT
I already have a dog leg 8 3/4 rear end with a 489 case under the Charger. I want a sure-grip/Posi to fix this problem.  :2thumbs:
well you have part of the parts already then
whats the gears on it ?
new carrier, new bearings on same case and allmost done... thats what I did.
had 3.23 and changed to 3.55, got a NOS set down here on a good price... bearings also locally... carrier from USA ( YUKON clutch kind  ). But can't find the seller... was loooong time ago. Seller set it up with soft grip for street use ( one spring washer per side instead two )
ACUDANUT
Thanks Nacho. Great lead. If I buy it, I will have to find someone who can rebuild mine.  :scratchchin:  I think I have 3.23 gears in my dog leg right now.
mopar0166
I looked up Dr. Diff, says it is out of stock.   I was looking at Moser which is about 1800.
Guess ill look for one at Carlisle swap meet.
ACUDANUT
My problem with swap meet parts (3rd members) is they can look like they work, but once you put it under the car and hammer it, they don't work.  Clutches or whatever wear out and it is a expensive gamble.
Been there, done that. Never again.
clutches expensive ?... I think they are on $70-80 rate, and can be done at home by yourself
